AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire front loader -- no water, no spinning
I have a Frigidaire GLTF1040AS0 front loading washing machine. When I try to run the machine, the "Door Lock" light goes on, but no water loads and the machine does not spin. Also even though the door lock light is on I can re-open the door with no difficulty. Any ideas what the problem could be? Thank you so much for your help!
Probably a bad door switch, would need meter to confirm.
Washer Repair
