Hi, in order to troubleshoot ignition failure on 2 of the burners, I tried to remove the spill tray (62A) by removing the burner. As mentioned elsewhere on this forum, to remove burner one has to remove the brass venturi on the burners. I used 20mm socket to unscrew the venturi. After a lot of effort & and 24" wrench, it turned, but it does not come off or even screw out. My question, does the brass venturi screw into the jet holder? I presume the nut holds the jet holder onto the sheet metal marked 39 in the parts dia? So if I turn the venturi anti-clockwise it should come out - right? But it does not & I can't pull it out (assuming it is out of the jet holder thread).
I am thinking that the venturi has seized to the jet holder and the whole assembly is turning round and round. How can I see what is it doing? Can I take out the front panel without taking out the entire cooktop?
It seems that this forum is not very active. After checking other forums, I did what they all said - you have to cut up the venturi to take out the burner and top cover. In my zeal, I managed to break the aluminum gas tubes. I got replacement venturi, nut & burner & gas tubes overnited & replaced them after cutting through them. I put anti-seize paste on replacement nut & venturi threads.
Turns out that my problem was a bad micro switch & a potentiometer. I replaced the microswitch & repaired the potentiometer by re-coating the bad traces by a conductive PCB repair pen that I picked up at Radio Shack. Cooktop works fine.
The moral of the story is that you should NEVER force the jammed venturi. If seized then simply cut it open after buying the replacements.
I have 2 extra sets of venturi, burner & nuts that I do not need, in case anyone wants to buy it.
