jeffrey_benjamin
#1 Posted : Thursday, July 15, 2010 5:56:32 PM(UTC)
jeffrey_benjamin
Hello to all I have this kenmore top freezer ref/frz. Having a problem where ice forms on the grill covering the evaporator fan motor. Ice does not block the coils & it works fine in both sections. Changed the Frz. door gasket. That didn't help. Also water drips from the top of the refrigerator section. Please help. :confused:
jeffrey_benjamin
richappy
#2 Posted : Friday, July 16, 2010 3:06:02 AM(UTC)
richappy
You might have a frozen drain. Remove the back freezer panel and check. I defrost them with hot water and a turkey baster.
jeffrey_benjamin
#3 Posted : Friday, July 16, 2010 5:27:57 AM(UTC)
jeffrey_benjamin
Thnks for quick responce the drain is clear no ice there & drain pan has water in it. :rolleyes:
richappy
#4 Posted : Friday, July 16, 2010 7:10:50 AM(UTC)
richappy
Look at the return ail ducts in the bottom of the fridg, may have an ice jam causing poor air circulation.
jeffrey_benjamin
#5 Posted : Friday, July 16, 2010 1:38:46 PM(UTC)
jeffrey_benjamin
hi richappy all that is clear. The ice that is building up is like snow & when it defrosts it will some times form little icicles. Freezer will keep ice cream solid & the ref.section has no spoilage. So far everything is good except for that ice forming on the fan guard (shield):confused:
jeffrey_benjamin
#6 Posted : Saturday, August 7, 2010 12:42:12 PM(UTC)
jeffrey_benjamin
I finally took this ref apart. found that the divider board was fully saturated. I replaced it along with the diffuser and all is well now :p
jeffrey_benjamin (Washer Repair)
by jeffrey_benjamin 7/3/2010 2:22:43 PM(UTC)
jeffrey_benjamin (Refrigerator & Freezer Repair)
by jeffrey_benjamin 4/24/2010 10:28:34 AM(UTC)
by jeffrey_benjamin 3/5/2010 10:20:55 AM(UTC)
by jeffrey_benjamin 11/18/2009 11:57:32 AM(UTC)
by jeffrey_benjamin 11/9/2009 11:57:46 AM(UTC)
by jeffrey_benjamin 11/9/2009 8:52:21 AM(UTC)
