joannie524
#1 Posted : Tuesday, July 13, 2010 1:00:55 PM(UTC)
joannie524
Rheem
Two ton gas pack unit, less than one year old.
The compressor makes a boom or thud every time it kicks on...to the point it keeps me awake. My old one didn't do this.
I called someone out and he said I needed a new fan blade which he installed. It changed nothing.
I am at my witts end. I don't know what to do. It is under warranty, but they don't seem to find the problem. Is there one or is this typical?
SublimeMasterJW
#2 Posted : Thursday, July 15, 2010 11:15:33 AM(UTC)
SublimeMasterJW
Check the compressor mounts. Maybe some packing material has not been removed from the install.
The Right Way HVAC Fall Maintenance To Do (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 9/29/2021 10:29:07 PM(UTC)
HVAC damper motor (Heating, Ventilation, and Air Conditioning (HVAC))
by cchen2 12/26/2016 7:08:59 AM(UTC)
Buying used HVAC system, good idea? (Heating, Ventilation, and Air Conditioning (HVAC))
by AppUser1 2/4/2014 12:28:28 PM(UTC)
Hvac Blower motor problem (Heating, Ventilation, and Air Conditioning (HVAC))
by jaywalker1981 9/12/2013 12:51:55 AM(UTC)
GE zoneline hvac (Heating, Ventilation, and Air Conditioning (HVAC))
by pmsage 12/27/2012 10:59:13 AM(UTC)
hvac unit gas (Heating, Ventilation, and Air Conditioning (HVAC))
by hev-v 12/23/2012 4:18:10 AM(UTC)
home hvac system wired wrong and shorted, help (Heating, Ventilation, and Air Conditioning (HVAC))
by hglarry 7/31/2011 1:32:12 PM(UTC)
Can a gas hvac be converted over to electric? (Heating, Ventilation, and Air Conditioning (HVAC))
by justonelaw 6/14/2010 8:23:17 AM(UTC)
HVAC heat elements stay on (Heating, Ventilation, and Air Conditioning (HVAC))
by mooney99 2/24/2010 2:44:15 PM(UTC)
Gas Valve On Lennox Hvac...bad??? (Heating, Ventilation, and Air Conditioning (HVAC))
by F1RUETER 11/3/2009 5:19:28 AM(UTC)
Magic chef hvac wall unit blower wheel (Heating, Ventilation, and Air Conditioning (HVAC))
by geiserberner 1/30/2009 1:35:28 PM(UTC)
HVAC not working after switching to new digital thermostat?!? (Heating, Ventilation, and Air Conditioning (HVAC))
by gaber79 11/18/2008 9:06:12 AM(UTC)
HVAC Blower is going nuts (Heating, Ventilation, and Air Conditioning (HVAC))
by halapeno 11/25/2007 9:47:37 AM(UTC)
