larry belanger
#1 Posted : Monday, July 5, 2010 2:11:10 PM(UTC)
larry belanger
my oven does not light up,,the pilot comes on when the selector switch is turned on to the required heat needed but the flame on the burner does not light up..I have changed the switch but still have the problem,,what shoud i be looking at next...regards larry
mebad247
#2 Posted : Tuesday, July 6, 2010 4:28:18 AM(UTC)
mebad247
Read the Help - instructions to install oven igniter sticky.
Good luck--found a replacement on ******** for 15.50 plus shipping.
GCRG3060AFC Frigidaire Gas Range Timer & Temp Display Error (Oven Repair (including Ranges and Cooktops))
by ChuckCastiglione 8/22/2021 7:09:15 PM(UTC)
HELP! Need clip or nut for Foot on Frigidaire Gas Range (Oven Repair (including Ranges and Cooktops))
by RichardKY 5/5/2020 6:43:52 AM(UTC)
frigidaire gas range (Oven Repair (including Ranges and Cooktops))
by Benitojuarez 1/27/2018 10:39:13 AM(UTC)
Frigidaire gas range will only ignite one at a time (Oven Repair (including Ranges and Cooktops))
by KevinD76 4/6/2015 8:07:28 AM(UTC)
Frigidaire gas range: Bake function inop (Oven Repair (including Ranges and Cooktops))
by Dave1175 3/6/2014 9:47:20 AM(UTC)
Frigidaire Gas Range/Oven (Oven Repair (including Ranges and Cooktops))
by beebem97 8/16/2013 2:28:34 PM(UTC)
Frigidaire gas range control panel--price? (Oven Repair (including Ranges and Cooktops))
by bpjdoc 8/3/2012 6:18:25 AM(UTC)
Frigidaire gas range model fgf379wecs....the oven doesn't always light off (Oven Repair (including Ranges and Cooktops))
by iajet 2/13/2012 7:10:12 AM(UTC)
Frigidaire gas range cook top grates (Oven Repair (including Ranges and Cooktops))
by learjetman 12/11/2011 5:39:05 PM(UTC)
frigidaire gas range oven (Oven Repair (including Ranges and Cooktops))
by repairmann 11/3/2011 3:56:48 PM(UTC)
Frigidaire gas range display out, oven not working (Oven Repair (including Ranges and Cooktops))
by landas214 4/29/2010 11:13:35 AM(UTC)
by snudden4 2/6/2010 3:28:20 PM(UTC)
frigidaire gas range control dim/not working (Oven Repair (including Ranges and Cooktops))
by kir26 9/14/2008 9:01:45 AM(UTC)
Frigidaire Gas Range wont ignite! Spark Module? (Oven Repair (including Ranges and Cooktops))
by Tractorshaft 8/20/2008 9:35:15 AM(UTC)
by nike 8/19/2007 4:29:03 PM(UTC)
