areamon
#1 Posted : Wednesday, June 4, 2008 12:36:22 PM(UTC)
areamon
My Tappan 12-1863-10/03 circa 1994 oven has stopped igniting, even though I have a bright orange electric ignition pilot. I cannot detect any gas flowing. I believe I have 2 items in the gas chain:
Regulator P/N
RV47NCLS
1/2 PSIG
Igniter P/N (I have electricity to this part)
9405 NAT
NC4148-5
774S014P02
Can you suggest a method to determine which is faulty and should be replaced?
#2 Posted : Thursday, June 5, 2008 12:31:56 PM(UTC)
Measure the current drawn by the igniter when it's on. If it's less than 3.2 amps - the igniter is bad and has to be replaced.
- The part number for the oven igniter is AP2150412
areamon
#3 Posted : Thursday, June 5, 2008 11:07:58 PM(UTC)
areamon
Gene,
I do not have the tools to measure AC current. I've disconnected the leads to the safety valve,P/N AP2139126 , and measured 1 ohm static resistance across its terminals; After turning the oven ON, I measured the AC voltage at the terminals (unloaded) at 114VAC. I turned the oven OFF, reconnected the leads and turned the oven ON, and again measured the voltage, now at 2VAC loaded, from 114VAC unloaded. Can I conclude that this igniter is the problem, or is the issue with the safety value?
Sincerely,
alr
#4 Posted : Saturday, June 7, 2008 6:07:40 PM(UTC)
Most likely the problem is a bad igniter.
You can learn how the oven igniter works from one of our previous posts:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1897-oven-wont-lite.html
areamon
#5 Posted : Sunday, June 8, 2008 8:16:59 AM(UTC)
areamon
Gene,
The igniter was replaced, and the problem was solved.
Thank you for your information
alr
#6 Posted : Sunday, June 8, 2008 9:56:43 AM(UTC)
I'm glad you were able to fix it.
6143
#7 Posted : Monday, August 18, 2008 3:03:57 PM(UTC)
6143
Tappan oven
6143
#8 Posted : Monday, August 18, 2008 3:08:11 PM(UTC)
6143
When turning on the oven, (digital panel) I smell gas and then the oven seems to ignite with a Poof sound thats strong.
#9 Posted : Tuesday, August 19, 2008 12:34:30 PM(UTC)
Most likely the problem is a bad oven igniter. Also I would recommend to check the burner for burned through holes.
- The part number for the bake burner is AP3220504
Guest (7)
