jeffrey_benjamin
#1 Posted : Saturday, July 3, 2010 2:22:43 PM(UTC)
jeffrey_benjamin
Hello back again with this GE washer WBSR3140G1WW rechecked the Lid & Pressure switches, they checked good. Fuse link is also good ( continuity down to motor on W/R wire. Also getting 120V across W/R & W wire to motor. Inverter board light flashes 6 times . Have continuity between Bl & Bk wires going into motor ( overload protector ) Still washer fills , drains but no agitation or spin. Help please:(
applianceman
#2 Posted : Sunday, July 4, 2010 7:57:32 PM(UTC)
applianceman
The six flashes means that the motor is locked. This could mean that the motor is bad or the sifter is locked/stuck. Try turning the big pulley on the bottom if the washer and if it turns freely the motor is bad and if not the sifter is bad.
There is one more thing that you should check. Fill the washer with water and see if the pulley on the bottom of the washer pushes down on and touches the bottom of the washer. If this happens the motor may flash that code and the motor may not turn. In this case the apron is bent. This is a common on problem with the earlier models but typically the motor will not hang when this happens but check to just to be sure.
HydroWave GE Washer Repair Guide
GE HydroWave Noisy Washer Repair Guide
The first page tell about the flashing light and the second tells about the sagging arpron.
jeffrey_benjamin
#3 Posted : Thursday, July 8, 2010 6:44:34 PM(UTC)
jeffrey_benjamin
Thank u for that usefull info. I replaced the motor and all is well again. the old motor was free. ASpron was in tact but it still only fill & drain. Thanks again for ur valued advice.
jeffrey_benjamin:)
jeffrey_benjamin (Refrigerator & Freezer Repair)
by jeffrey_benjamin 7/15/2010 5:56:32 PM(UTC)
by jeffrey_benjamin 4/24/2010 10:28:34 AM(UTC)
by jeffrey_benjamin 3/5/2010 10:20:55 AM(UTC)
by jeffrey_benjamin 11/18/2009 11:57:32 AM(UTC)
by jeffrey_benjamin 11/9/2009 11:57:46 AM(UTC)
by jeffrey_benjamin 11/9/2009 8:52:21 AM(UTC)
