i have a whirlpool side by side with a broken water line inside freezer door. can i replace it and how? model is ed5phaxsboo
Yes, it can be done. You have to order new fitting kit. The instructions are attached to the reply. - The fitting Part number: AP3179954
i have a kenmore side by side that i need to change the water line in the freezer door as well.... model number 106.56663500. how do i get to the waterline to replace it?
Did you read the previous post?
The instructions are attached to it and you can use the same part number.
Originally Posted by: lad740 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i have a whirlpool side by side with a broken water line inside freezer door. can i replace it and how? model is ed5phaxsboo What if I have a GE side by side Gss25sgmdbs? The line is cut at the bottom hinge, so I need to replace the line. Is it the basic same assembly or is something else needed?
Originally Posted by: eugermach ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What if I have a GE side by side Gss25sgmdbs? The line is cut at the bottom hinge, so I need to replace the line. Is it the basic same assembly or is something else needed? It is more complicated with this refrigerator. Click on the part number or picture bellow and scroll down to the Q & A section for the installation instructions. - The tube assembly Part number: WR17X11116
Gene: Thanks, that was the part I thought I needed, but is there anywhere where I can determine if door panel needs to be removed. I thought I would be able to take apart the ice maker panel, and pull the tube out and rethread. The diagram from GE does not indicate how the line is threaded through.
Any direction would be appreciated.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Click on the part number or picture bellow and scroll down to the Q & A section for the installation instructions... Did you do it? Gene.
Gene:
I got the part, but I am not sure how this escutcheon or trim plate is removed. I do not want to break it, and am not positive on how to remove. Any help to get it off will be appreciated. Some forums discuss pushing and removing by the tabs. Not sure how it works.
I went to Ace and bought 6 inches of rubber water hose, $1.89 that would fit both side and used hose clamps. Cut out hole and attach hose and use the hose clamps. Mine has been working ever since, for years, mine is a GE pss29ngmbcc. The water line cracked in two places where the line bent to sharp when it was only 2 years old. GE wanted $275 to replace the line. GE should of just used good plastic hose intead of being CHEEP.
