2 Pages12>
Victor Scott
#1 Posted : Monday, June 28, 2010 9:00:35 AM(UTC)
Victor Scott
Hi,
My 13-year-old Maytag washer sloshes water over the basket and wets the floor. I recently changed the water level switch because at times the water level seemed too high.
With the new switch, I set the water level at "medium", and even so water sloshes out of the basket.
Months ago, I changed the pump and agitator belts because they were worn and back then water was sloshing out of the basket too
This sloshing is strange behavior... Can someone help me here?
Thank you
Victor :confused:
sidfink43
#2 Posted : Wednesday, June 30, 2010 12:12:21 PM(UTC)
sidfink43
If the water level is still too high clean out the tube coming from the water level switch to the tub.
Victor Scott
#3 Posted : Friday, July 2, 2010 10:01:32 AM(UTC)
Victor Scott
Syd, Thank you for your response.
Before I bought the waterlevel switch I blew into the levelswitch tube and it was clear... didn´t seemed clogged up or anything. What do you suggest I try from here?
Thank you,
Victor
sidfink43
#4 Posted : Friday, July 2, 2010 11:30:51 AM(UTC)
sidfink43
Is it sloshing out because the water level is too high, or because the motion is too strong.
If the water level is too high you may have gotten a defective water level switch. Yeah, not likely but that is the best explanation.
Victor Scott
#5 Posted : Monday, July 5, 2010 4:37:00 AM(UTC)
Victor Scott
Sid,
Hi. I cleaned out the waterlevel switch tube -- indeed it was full of gunk and crud. You were right about that! After that, I have no problem with water level. Now, I think the motion of the agitator is too strong or fast. I observed the agitator working by activating the lid switch--it does seem to be strong. What can I do about that?
sidfink43
#6 Posted : Monday, July 5, 2010 6:25:26 AM(UTC)
sidfink43
There is no adjustment, and given the age of your machine see if a water level setting works at a level that you can live with it rather than undertaking a costly repair.
Victor Scott
#7 Posted : Monday, July 5, 2010 7:05:11 AM(UTC)
Victor Scott
Sid,
Thank you very much for your advice. I am trying to prolong the life of this washer the most I can, but if it doesn't work well with a different water level I think I will retire it. Regards, Victor.
nocodrew
#8 Posted : Monday, July 25, 2011 4:28:25 AM(UTC)
nocodrew
Howdy,
So does age of a machine cause the agitator to move too strong?
Thanks,
Drew
nocodrew
#9 Posted : Monday, July 25, 2011 4:34:00 AM(UTC)
nocodrew
Originally Posted by: nocodrew Go to Quoted Post
Howdy,
Thanks,
Drew
Also, is there a way to diagnose my machine to make sure it is working properly at each stage. For example, is it suposed to spin during the agitate cycle?
sidfink43
#10 Posted : Monday, July 25, 2011 5:23:50 AM(UTC)
sidfink43
It is not supposed to spin during agitation, and this implies a brake problem or a transmission problem
2 Pages12>
