AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Dryer will not start on high heat cycle
Hi, i'm new to the forum and would like some help.
I have a whirlpool dryer, and this morning, the dryer operated just fine on the first load. But it would not start on the second load. So I thought it need to cool down first. So i waited, but it would not start. Then I found out that the dryer worked fine when it was on a low heat cycle. I usually use the dryer on high heat cycle.
So the problem is that the dryer will not start on a high heat cycle, but it works fine on low heat cycle.
Can anyone help? Thanks!
Dryer Repair
