2 Pages<12
#11 Posted : Friday, June 25, 2010 3:22:03 PM(UTC)
I would not do it. This thermal cut off is a safety device to prevent the magnetron overheating. You can end up with fire in your kitchen and/or radiation leakage.
Longjack
#12 Posted : Friday, June 25, 2010 3:49:45 PM(UTC)
Longjack
Thanks Gene.... as always....
Longjack
#13 Posted : Thursday, September 9, 2010 8:47:52 AM(UTC)
Longjack
OK... 2 months later I'm back and here is what I found...
When I last posted, had figured out that my magnetron thermal cutoff was bad, but could not find the part.
On the bad part, it says
CS-7TA
180-15A
X147
Don't know if the 180 if F or Centigrade, so to be safe went with this thrid party part -
Thermal Cutoff part # 18QBP088H
which is supposed to be a 190 degree Farenheit
Installed it, and started microwave, and after about 2 minutes, it shuts entire microwave off and no lights on front panel...BUT..within about 3-4 minutes, I get lights back and can start it again.
So... I am wondering if the 180 could be referencing Centigrade? If so, the only magnegtron thermal cutoff I can find goes to 149 degress Centigrade...
Would installing this one be my best next attempt, or is something else need to be checked? Thanks...
#14 Posted : Thursday, September 9, 2010 8:53:19 PM(UTC)
Does the cooling fan behind the control panel work?
Longjack
#15 Posted : Friday, September 10, 2010 5:28:52 PM(UTC)
Longjack
Hi Gene..thanks for responding...
Yes, fan seems to work fine... and by the way, on Defrost cyle, I ran the microwave for about 10 minuites without an issue today (which I think is about 35% power?).
It's a convection microwave, but have not tried the convection oven part yet, as I primarily use the microwave feature.
#16 Posted : Friday, September 10, 2010 5:35:13 PM(UTC)
If the cooling fan is fine, then the thermal cut off is probably wrong.
Longjack
#17 Posted : Tuesday, September 14, 2010 10:47:06 AM(UTC)
Longjack
Sorry for the delay, but internet here is iffy sometimes...
Thanks for the input... will go with higher temp cutoff and report back, but may take a few weeks.... many thanks again.
Guest (7)
2 Pages<12
