Refrigerator temp is too cold on lowest setting. Ice in beverages. Freezer is ok. Is this a bad thermostat?
How exactly did you set both controls (numbers)?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How exactly did you set both controls (numbers)?
Gene. I'm not looking at the controls at this time however I know that the setting for the refrigerator is on 1 and it's stii too cold. The freezer seems to be fine. Thanks for your help
It is important how did you set the freezer control too.
Gene, I checked the freezer control setting and it was on 7 which is the highest setting. I have moved it back to 6 to see if that won't keep everything cold enough. Any advice? Thanks.
Set the freezer control on 3 and wait about 24 hours. Put a thermometers in both compartments.
Gene, I will follow your instructions. Since we are going into weekend and I'm sure we won't be able to correspond, please advise what temps I should expect or hope to see in each compartment and what should my next move be. Thanks again for all your help. Jeff
Jeff,
Normally it suppose to be about 0°F in the freezer and between 35°F to 39°F in the fresh food.
