dawabu
#1 Posted : Thursday, June 24, 2010 2:59:24 PM(UTC)
dawabu
How do I remove the motor pulley which seems fused to motor?
richappy
#2 Posted : Friday, June 25, 2010 3:06:30 AM(UTC)
richappy
I would tap it off with a small hammer. You are lucky they sell the pulley for this.
#3 Posted : Friday, June 25, 2010 5:13:22 AM(UTC)
This may also help
http://www.servicematters.com/maytag_library/docs/16023083.pdf
See page 7-6 and 7-7.
Here is some additional info
http://www.servicematters.com/maytag_library/docs/TDL-0143-B.pdf
Here is a replacement pulley, looks like the short on in the above bulletin
Part number: AP4024152
Click on the above picture a new page should open with new views.
Click on the center picture and you will see the little teeth that hold the pulley onto the motor shaft.
how to remove motor pulley? (Washer Repair)
by turchekj 8/11/2010 8:46:02 AM(UTC)
