lauriem
#1 Posted : Wednesday, June 23, 2010 9:57:44 AM(UTC)
lauriem
I have a whirlpool window a/c, and I need a part. but dont know what its called, so I will attempt to describe
Made of stryofoam
fits on top of unit under metal casing
goes over the fan and assembly
regulates cold air to fan
I no longer have this piece and I need it or something to replace it.
Please help
Laurie:confused:
kooler
#2 Posted : Friday, July 2, 2010 10:38:24 AM(UTC)
kooler
Hey Laurie, APPros does have a diagram of your model listed but I'm unsure of what part you're looking for - it could be #7 Housing P/N AP3594377 but that part is a special item; you have to call APPros for availability at 8774777278.. The other possibility is #9 Scroll P/N AP3607391 which is available... The diagram doesn't specify what material each part is constructed of so a little more research on your part is necessary... Good luck, cheers
lauriem
#3 Posted : Friday, July 2, 2010 10:42:05 AM(UTC)
lauriem
Ty so much for your help I will check it out
Laurie
