I bought this unit used (unit was never installed), got it home, wired it up and got these error codes. The first code (E0 F2) tells you to replace the keypad. The code now (E1 F2) suggests to replace the board. Does anyone know the part numbers (I don't know what parts the "keypad" and "board" refers to) and price of these items? Sincerely and Thankfully, Pat
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene, I had already done this on both connectors (keypad and board) and checked continuity on all the leads through the ribbon cable - all are OK. I was hoping someone could lead me to either the touch keypad or the main board for replacement. I don't know which one to try first and they're both fairly exspensive. My Sincerest Thanks for your time and advice, Pat
Pat, According to the tech sheet the first try should be the membrane switch (keypad). If you need the correct part number, post the color of it. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Pat, According to the tech sheet the first try should be the membrane switch (keypad). If you need the correct part number, post the color of it. Gene. Gene, you're a very helpful guy/gal and I want you to know I appreciate all your help. I ordered the keypad and am crossing my fingers. My Sincerest Thanks, Pat
You are welcome Pat.
Hopefully it will fix the problem. Good luck and keep us posted.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You are welcome Pat.
Gene. Bingo, right on the money! The keypad fixed the problem and my wife is cooking brownies - Woo-Hoo! Thanks Again Gene!
