ringo
#1 Posted : Saturday, June 19, 2010 8:50:19 AM(UTC)
ringo
I'm having a problem with my jenn-air stove. The cooling fan comes on at 105 degrees, and blasts out hot air into our kitchen. From internet info. I need a new relay board. None of your diagrams for this model shows this part. It is supposed to be behind the back panel of the stove. Your help would be appreciated in locating the part number, and availability. Thanks
#2 Posted : Sunday, June 20, 2010 2:30:30 AM(UTC)
As far as I can see your unit does not have a separate relay board.
Here are the parts
Replacement parts for JENN-AIR JES9860AAB Range - S/c S/i Ddraft Ele | AppliancePartsPros.com
Here is a manual includes service, install and operators sections
http://www.servicematters.com/maytag_library/docs/16025927.pdf
Here is a tech sheet for sometimes they vary from the more generalized service manual.
http://www.servicematters.com/maytag_library/docs/16025924.pdf
Looks like the fan is directly run from the control board and my guess would be that the way it is working is normal.
