kmyres76
#1 Posted : Tuesday, June 15, 2010 1:35:05 PM(UTC)
kmyres76
My washing machine goes all the way through the cycles, agitates and everything, but will not spin or drain. Help?
dickleam
#2 Posted : Wednesday, June 16, 2010 3:11:03 PM(UTC)
dickleam
Kenmore Model 110.20922990 Fills and agitates but will not spin or drain.
jeanfix
#3 Posted : Monday, June 21, 2010 10:06:01 AM(UTC)
jeanfix
i discovered seconds before delivery of new Kenmore washing machine...that SWITCH very easy to see under the lip of the machine..needs to be replaced. I'm looking for HOW to do? I found the part. It looks easy, but looking for diagram and info....
jeanfix
#4 Posted : Monday, June 21, 2010 10:07:55 AM(UTC)
jeanfix
I have MODEL 110 92480200 Kenmore Heavy Dute 80 Series..It works, it just needs a new switched installed and trying to see if I can do myself...any advice on "HOW To?" or shld I just call....Sears home repair....? The part is available..
dickleam
#5 Posted : Monday, June 21, 2010 11:49:36 AM(UTC)
dickleam
Hi, My washer is a Kenmore series 90, Model #110.20922990 and replacing the lid switch solved my problem. I don't know what differences there are between the series 80 and 90, but the following web site has photos and detailed instructions that include replacing the lid switch for a series 90 Sears Kenmore Washing Machine Repair I hope it may be of some use to you. My biggest problem was either waiting a week for the part to arrive or driving 100 miles to pick it up at a Sears parts center... I chose to make the trip. It only took about 15 minutes to replace the switch once I had it in hand. Hope this is of some use to you.
