tmatthews
#1 Posted : Wednesday, May 14, 2008 1:50:41 PM(UTC)
tmatthews
My dryer is squeaking when it is drying. The heavier the load the louder it squeaks. What could be causing this?:confused:
SublimeMasterJW
#2 Posted : Wednesday, May 14, 2008 5:48:24 PM(UTC)
SublimeMasterJW
Let me see if I can write down what the sound is you hear
Eeeeooop Eeeeooop Eeeeooop
let me find you a picmain board top.JPGThis guy right here is less than 10 bucks and it mounts on the rear bearing assembly. To access it you gotta remove the front panel and drum. Open the door and remove the screws located at the top, then raise the top and remove the panel. Get the drum out this part mounts on the tip of the drum center.
SublimeMasterJW attached the following image(s):
juliaannm
#3 Posted : Thursday, May 29, 2008 7:36:31 AM(UTC)
juliaannm
Hello...i Am Having The Similiar Problem...my Dryer Squeaks Horrbily (high Pitched) With A Wet Load But If It Is Dry And Just Dewrinkling Or 1 Or Two Pieces Wet Then No Noise...do You Still Think It Is Just The Rear Bearing? Thanks.
SublimeMasterJW
#4 Posted : Thursday, May 29, 2008 12:34:32 PM(UTC)
SublimeMasterJW
A dryer like this makes 2 diff noises of distintion, one is the above mentioned. The other is that of a car that needs rear brakes, Metal to metal scrubbing. Squeal=rear bearing, scrub= drum slides.
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
