leafhppr
#1 Posted : Monday, June 7, 2010 5:50:01 PM(UTC)
leafhppr
Hi there,
My air conditioning is always on, even after I turned control switch for the blower or turn off the thermostate. The only way to turn it off is to cut the electricity from circuit breaker.
Any idea?
Thanks,
Ning
leafhppr
#2 Posted : Monday, June 7, 2010 5:51:16 PM(UTC)
leafhppr
I have Comfortmaker RPJ II (heating and cooling). Thanks.
icehouse
#3 Posted : Monday, June 7, 2010 6:22:57 PM(UTC)
icehouse
Check wiring. Also furnish Model number
leafhppr
#4 Posted : Tuesday, June 8, 2010 4:08:21 AM(UTC)
leafhppr
Thanks for your reply. Please advise which wiring I need to check. The machine worked fine just a few days ago and blower and controller seem all working (automatically turned on/off), except air conditioning never stops. Very strange.
jackssib1
#5 Posted : Friday, June 11, 2010 4:25:25 AM(UTC)
jackssib1
My unit is doing the same. runs, all the time gotta shut it off by switching off power, lol:mad:
icehouse
#6 Posted : Friday, June 11, 2010 6:19:39 PM(UTC)
icehouse
Disconnect the yellow wire on thermostat and see if A/C stops.
icehouse
#7 Posted : Friday, June 18, 2010 5:34:13 PM(UTC)
icehouse
Originally Posted by: northshore Go to Quoted Post
It sounds like the contacts in the fan relay are sticking. For more information visit: Northosre appliance repair
:eek: O/P Stated that that the blower (fan) stops,therefore the fan relay is not sticking. Sounds like the compressor contactor is sticking. Removing the yellow (to compressor contactor coil ) will prove this.
