Our Whirlpool Quiet Partner II does not run. The model number is DU1145XTPQ6. I put the age as 1-5 years, but I'm not certain about that because it was purchased by a former owner of our house. The symptoms are the same as described in a posting from jimc lmc (03-04-2008, "Whirlpool Quiet Partner III will not run.") That is, the "clean" LED flashes slowly and pauses, then flashes 7 times and pauses, etc. I would like to try the suggestions offered by bambiblaster (03-04-2008) , but I checked behind the toe panel and could not find the tech sheet with all of the test procedures, and I couldn't quite follow the description of the procedure in the posting. Is there a place where I can get a copy of the procedures used to test/troubleshoot this model.
I appreciate any help/advice that you can provide
Here are the tech sheets for your dishwasher. Try to reset the error code as described there. If it would not help then you have to check for continuity the heating element and the hi-limit thermostat. Gene.
Hi...I have the same model Quiet Partner II and am getting the constant flashing light on the cancel button. I tried the normal--heated-dry x4 combo and it doesn't work. I also tried the sani--heated combo with the same affect...nothing. It was working fine before then all of a sudden this. Any help would be greatly appreciated.
Originally Posted by: Teg  ...the constant flashing light on the cancel button... This error code indicates very different problem which is a shorted pad on the control panel. The correction is to replace the control panel. If you need the correct part number, post the complete model number of the dishwasher and color of the control panel. Gene.
Thanks for that info...sort of. Is there a way to get the model # short of pulling the machine out? And do you know a ballpark $$$ for a control panel?
Originally Posted by: Teg  Thanks for that info...sort of. Is there a way to get the model # short of pulling the machine out? And do you know a ballpark $$$ for a control panel? The model number is on the door frame and you will see it right after you open the door. Price can be from bellow $100 and up to over $200. Gene.
My dishwasher is approx. 3yrs. old and for at least the past 6mos. I'm having a problem with the control panel lights blinking. I just tried the 4x sequence and when I press the Normal button, the Pots/Pans button starts flashing? I tried both the Start and Cancel button and nothing happens. It will now take at least an hour or longer for the buttons to stop flashing. We've shut down power completely to try to reset it but other than that we just have to wait for the blinking to stop. Sometimes it'll take a week before we can use it again. Is this fixable or is it going to cost more than it's worth?
Which lights are blinking more?
What is the complete model number and the color of the dishwasher?
I too have a Quiet Partner II (model# DU1100XTPBA) that has a rapidly blinking Cancel light while at the same time the Normal & Light cycle lights are rapidly alternating. Nothing has any effect on the cycling. Without the tech sheet, I have to assume these patterns imply some specific diagnostic indication. I'm hoping another forum member might be able to offer some suggestions or maybe even a link to the model's tech sheet? Many thanks for any feedback, -Steve
