paulina1013
#1 Posted : Wednesday, June 2, 2010 11:11:48 AM(UTC)
paulina1013
Hi, my Maytag (top loading) fills with water but will not agitate. I have checked the belts-they are fine. When I pull the belts underneath the agitator will turn. I can hear the knob mechanism humming when I pull the knob out to start the machine, but no agitation. No matter which setting I put the machine on, it will not agitate. I vaccuumed the water out and it refills just fine. HELP!!!! What's the problem?
#2 Posted : Wednesday, June 2, 2010 6:30:57 PM(UTC)
Check both switches (#5 & #16 on the diagram) on the lid switch assembly.
Check the water level switch for continuity between the terminals 7 & 16 while the washer full of water. If there is no continuity, replace the water level switch.
- The lid switch assembly Part number: AP4026359
Maytag Will not Agitate or spin (Washer Repair)
by SNielson 4/22/2022 7:50:35 PM(UTC)
Maytag will not agitate (Washer Repair)
by 1hkfan 4/6/2014 9:15:38 AM(UTC)
Maytag will not agitate,but will pump out and spin (Washer Repair)
by willnise 6/13/2012 11:34:51 AM(UTC)
