2 Pages12>
joverwy
#1 Posted : Friday, May 23, 2008 8:57:30 PM(UTC)
joverwy
7 year old Kenmore microwave suddenly stopped working, didn't seem to want to turn off. It displays only F6. Should I pay to have it repaired or ust buy a new one?
#2 Posted : Friday, May 23, 2008 9:16:38 PM(UTC)
What is the complete model number?
How much did you pay for this microwave?
mbreezy
#3 Posted : Monday, August 25, 2008 3:46:36 PM(UTC)
mbreezy
I have a Kenmore Micro with the same F6 problem! I see 2 requests for help on this site but no resolutions for either one.:(
libertyappl
#4 Posted : Monday, August 25, 2008 3:47:45 PM(UTC)
libertyappl
With out a model number we can't help much.
Nat
mbreezy
#5 Posted : Monday, August 25, 2008 3:48:39 PM(UTC)
mbreezy
model #66569687992
libertyappl
#6 Posted : Monday, August 25, 2008 3:59:26 PM(UTC)
libertyappl
Check this....
F6 Microwave relay failure
1. Unplug microwave oven or disconnect power.
2. Check wiring to Relay 4903 for short circuits.
3. If wiring is OK, replace electronic control.
4. Plug in microwave oven or reconnect power
This is on a Whrilpool microwave, which who made the 665 model you have.
Nat
mbreezy
#7 Posted : Monday, August 25, 2008 4:06:15 PM(UTC)
mbreezy
While I was waiting, I took off the panel, found the tech book, and inside it says an F6 is a relay failure.
How do I Check wiring to Relay 4903 for short circuits? Where is relay 4903. Sorry, I am a software architect, just trying to learn....
mbreezy
#8 Posted : Monday, August 25, 2008 4:20:47 PM(UTC)
mbreezy
I took off the key panel, found the 4903 relay label on the diagram, but cannot find the relay on the board. Any suggestions?
mbreezy
#9 Posted : Monday, August 25, 2008 5:07:40 PM(UTC)
mbreezy
I took off the panel, found the relay, tightened up the connection, put the panel back on, and Voila! I have a working microwave again, thanks!
libertyappl
#10 Posted : Monday, August 25, 2008 5:38:40 PM(UTC)
libertyappl
You're welcome, sorry it took so long to get back with you had to put up the goats & chickens :0)
Please post where you found the relay it might save us some time re-posting everything.
Nat
Hotpoint/GE/Kenmore microwave blowing fuses (Microwave Repair)
by mje2019 10/21/2020 1:36:17 PM(UTC)
kenmore microwave (Microwave Repair)
by phi2cor 1/30/2014 5:24:34 PM(UTC)
Kenmore microwave 85470 (Microwave Repair)
by Binger 12/27/2012 7:17:48 PM(UTC)
Kenmore Microwave hood combination (Microwave Repair)
by curtisd 8/4/2012 1:21:52 PM(UTC)
Kenmore Microwave (Microwave Repair)
by jlezette 12/26/2011 1:43:32 PM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
kenmore microwave, runs when plugged in, wont shut off (Microwave Repair)
by ice3x 6/27/2011 8:17:33 AM(UTC)
kenmore microwave has f2 error code (Washer Repair)
by bobval 4/29/2011 6:00:09 PM(UTC)
Kenmore microwave hood combo, no heat (Microwave Repair)
by billbr 9/28/2010 8:59:29 AM(UTC)
Replace Kenmore Microwave Door Latch (Microwave Repair)
by kwells 7/3/2010 2:57:56 PM(UTC)
by SheriO 5/5/2010 7:50:07 AM(UTC)
'F3' display on the Kenmore microwave screen (Microwave Repair)
by jennifer555 3/25/2010 6:00:52 PM(UTC)
Kenmore Microwave no heat (Microwave Repair)
by desgross 11/11/2009 5:53:21 AM(UTC)
Kenmore microwave does not heat (Microwave Repair)
by srikki9 9/7/2009 11:15:49 AM(UTC)
Kenmore Microwave -No Heat, No Turntable -Related? (Microwave Repair)
Belarus airheads 7/12/2009 12:40:12 PM(UTC)
2 Pages12>
