washer does not agitate all other function work
Does the motor run in agitate mode?
Does the motor run in agitate mode? If it does, you probably have a bad transmission.
Originally Posted by: duane ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) washer does not agitate all other function work Washer does not AGITATE all other functions work fine.
If this particular washer does everything but agitate I have found the problem is in the timer most likely.
