oldsurfman
#1 Posted : Monday, May 31, 2010 4:39:23 PM(UTC)
oldsurfman
I've read the sticky on the defroster section. What 2 test points to check
fpr the ohm reading .I see the orange on pin 9 of the J7 connector but I don't have a " terminal J9 defrost heater"?
richappy
#2 Posted : Tuesday, June 1, 2010 3:11:51 AM(UTC)
richappy
Most probable problem is your defrost heater, just remove and test.
oldsurfman
#3 Posted : Tuesday, June 1, 2010 3:15:04 AM(UTC)
oldsurfman
Thankyou I'll try that .Seems easy enough to remove.
oldsurfman
#4 Posted : Tuesday, June 1, 2010 10:01:14 AM(UTC)
oldsurfman
Thanks for the help.I removed the heater and checked it.Infinate ohms.Took off the end cap and the element was broken ,will order new one.
richappy
#5 Posted : Wednesday, June 2, 2010 12:53:42 AM(UTC)
richappy
Very good. I'v learned the hard way to go after the most probable problem, which is usually the easiest to diagnose and repair.
