lp33852
#1 Posted : Friday, May 28, 2010 3:55:41 PM(UTC)
lp33852
the dryer will not heat when the wires are where they belong.when i put the wiers some where elce it heats but at one point it poped the braker so i dont know if it still heats my mom was messing with it too after me so if you can help mess me on my email colejustincdl@yahoo.com thanks
#2 Posted : Saturday, May 29, 2010 2:35:29 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for ADMIRAL ADE7005AYW Dryer - Ele | AppliancePartsPros.com
[COLOR="Blue"]when i put the wiers some where elce it heats but at one point it poped the braker[/COLOR]
Doing the above without knowing what you are doing is going to end up with one of the following:
You will burn the house down
OR
Electrocute yourself [COLOR="Red"]240 VOLTS KILLS[/COLOR]
Make sure that the wires are back where they are supposed to be.
If not sure get a pro in.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats for continuity.
Heating coil, should be 10 to 12 ohms approximately.
Thermostats (cycling and hi-limit) should be 0 ohms.
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Estate Model Dryer not heating properly (Dryer Repair)
by eaaron63 7/28/2013 3:46:48 PM(UTC)
by Sangues 1/1/2013 2:31:57 PM(UTC)
Admiral gas dryer not heating properly (Dryer Repair)
by moonflower23 2/4/2012 10:35:54 AM(UTC)
by Rigdawg58 12/13/2011 1:59:35 PM(UTC)
by jjdm71 10/3/2011 11:12:52 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by mnova127 4/27/2010 7:35:53 PM(UTC)
Maytag dryer not heating properly (Dryer Repair)
by vpolitano 1/18/2010 9:37:23 PM(UTC)
