2 Pages12>
Johndym
#1 Posted : Wednesday, May 21, 2008 2:50:15 PM(UTC)
Johndym
The spin cycle didn"t work but there was a loud noise and something spinning
could be heard. What could it be on this old machine(20 some years)?
How can I get to it?
misterfixall
#2 Posted : Wednesday, May 21, 2008 3:36:37 PM(UTC)
misterfixall
does it wash? open back cover .check large pulley on right side, see if it wobbles.
Johndym
#3 Posted : Wednesday, May 21, 2008 4:36:37 PM(UTC)
Johndym
There's only a small panel in the back lower left about 151/2"x151/2".
I took it off and only saw the motor, tub and some electrical components
but no pulley. The washer did go through some of the wash cycle if not all
but it would not spin in the rinse cycle.
Sorry,I looked again and saw a very obvious large pulley on the right
and a small pulley on the left.The belt seems to be in good condition
and it can be turned easily by hand. The pullies have no wobble.
richappy
#4 Posted : Thursday, May 22, 2008 2:43:16 AM(UTC)
richappy
Lift up the outer spin solenoid plunger and turn the belt. The slide should move to engage the clutch and the basket should start spinning. Post results.
Johndym
#5 Posted : Thursday, May 22, 2008 6:00:21 AM(UTC)
Johndym
Richappy,
What does the outer spin solenoid look like and where is it?
Johndym
#6 Posted : Thursday, May 22, 2008 5:11:56 PM(UTC)
Johndym
I'm still not sure what the outer spin solenoid plunger is. can someone help
me on this so that I can try what Richappy suggested?
richappy
#7 Posted : Friday, May 23, 2008 2:13:15 AM(UTC)
richappy
You have a dual solenoid mounted to the transmission. Just lift up the plunger on the solenoid on the left side next to the side wall. Then pull the belt clockwise till it goes into spin.
Johndym
#8 Posted : Friday, May 23, 2008 6:36:43 AM(UTC)
Johndym
richappy,
The diagram for this model doesn't show a transmission. Only a motor and
pump assembly are attached to the pulley. I'm still confused on this.
Johndym
#9 Posted : Friday, May 23, 2008 10:06:41 AM(UTC)
Johndym
I looked at the thread by debjames and looked up the Model#. The parts
look closer to what I see than for the model # on my machine. It could be some of the parts could have been changed by the repairman we bought it from over 20 years ago.
I see two cam bars and two plungers. I tried lifting them both one at a time,
while turning the belt from right to left until one or the other would stay up.
The result is that I believe the inner most plunger (further away from the
panel door) controls the spin. So I turned the belt while holding that plunger up until the belt tightened and could no longer be turned. The plunger would then stay up. I turned on the machine to approximately the spin cycle and it started to spin for a few turns then stopped spinning but the
belt was still turning.
I repeated this with the plunger toward the door. It took a number of turns before this plunger would stay up but the belt did not tighten as with the
other plunger. It very weakly agitated but then stopped and the belt was
still turning.
Is this repairable or am I looking at another washer? If so, any recommendations on washers (new or used)?
I forgot to mention that I did these tests with the water turned off. Does this make a difference?
richappy
#10 Posted : Saturday, May 24, 2008 2:40:09 AM(UTC)
richappy
If the motor is turning in spin, you either have a broken wire at the solenoid, a bad solenoid, or a bad timer.
Guest (7)
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
2 Pages12>
