Kodiak
#1 Posted : Monday, May 19, 2008 5:44:37 PM(UTC)
Kodiak
Have a GE single wall oven that is 17 1/2 years old. It doesn't heat evenly, browns tops of items but inside not done.
I ran a check on it for one hour with an oven thermometer inside at 350 degrees & checked it every 5 minutes. It varied from 340 - 380 degrees. Does this indicate the need for a new thermostat? Is it wise to spend $200 on a part for an oven that old?
Have been looking at a new Kitchenaid Model # KEBK171SBL but have been reading horror stories on-line about when using the self-clean the oven would clean then not work again until new parts were put in. Do you know anything about this?
Kodiak
#2 Posted : Monday, May 19, 2008 5:46:51 PM(UTC)
Kodiak
#3 Posted : Tuesday, May 20, 2008 2:52:25 PM(UTC)
Which cycle did you use when you cooked? Bake or Broil?
Where did you place the thermometer during the test?
There was an ongoing problem with some Whirlpool and Kitchen Aid oven models due to improper air flow during self clean cycle, causing the thermal fuse to blow. Hopefully they fixed this issue on the newer models.
Kodiak
#4 Posted : Tuesday, May 20, 2008 7:56:00 PM(UTC)
Kodiak
Gene,
Cooked on Bake. My oven has 5 rack positions & I placed the oven thermometer on the 3rd rack (3rd down from from the top). This is the position I usually use, except when broiling.
Kodiak
#5 Posted : Tuesday, May 20, 2008 8:02:25 PM(UTC)
Kodiak
I cooked on "Bake". My oven has 5 rack positions & I placed the oven thermometer on the 3rd rack position (3rd down from the top). This is the position I usually use, except when broiling.
Thanks for info on Kitchenaid.
Kodiak
#6 Posted : Tuesday, May 20, 2008 8:18:51 PM(UTC)
The difference in the oven temperature within 25°F range for such old oven with the electric-mechanical thermostat is pretty normal.
On another side there is a good chance the new thermostat will make it better and your decision should be based on the age and the condition of the unit and your wife's preferences.:)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
KERS206XSS1 thermostat replacement part (Oven Repair (including Ranges and Cooktops))
by Guest 1/23/2024 3:59:52 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
Freezer Thermostat Replacment (Refrigerator & Freezer Repair)
by homerepairbyneed 5/29/2023 12:14:10 PM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Samsung Thermostat -- open or closed at room temp (Microwave Repair)
by Guest 8/29/2021 9:03:07 AM(UTC)
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Whirlpool thermostat not working (Refrigerator & Freezer Repair)
by tomok 5/17/2021 8:40:02 AM(UTC)
Wire two wire thermostat to coleman furn. (Oven Repair (including Ranges and Cooktops))
by Guest 4/4/2021 3:46:08 AM(UTC)
FDB750RCC2 Thermostat and Heating Element Connectors (Dryer Repair)
by beatrice109 3/26/2021 11:46:30 PM(UTC)
Amana Refrigerator Thermostat? (Refrigerator & Freezer Repair)
by yaworski 3/24/2021 10:42:55 AM(UTC)
Need thermostat control 216521100 (or alternative) for Frigidaire FFU20F9FW3 freezer (Refrigerator & Freezer Repair)
by MSStateDawg 1/21/2021 8:20:33 AM(UTC)
GE TFX27F stops cooling until reset via thermostat (Refrigerator & Freezer Repair)
by Gary Hall 12/2/2020 6:32:23 PM(UTC)
G.E. Replacement Thermostat (Oven Repair (including Ranges and Cooktops))
by StCrispin 11/23/2020 11:46:08 AM(UTC)
