dryerman101
#1 Posted : Monday, May 24, 2010 8:51:59 AM(UTC)
dryerman101
On spin cycle washer makes loud clunking noise, almost like it has an unbalanced load. I took all the clothes out and still heard the noise on the spin cycle,help me out.
#2 Posted : Monday, May 24, 2010 1:14:28 PM(UTC)
Very likely the problem is a bad clutch (#5 on the diagram).
You have to remove the washer cabinet, the pump and the motor, the agitator and the inner tub and drop off the transmission. You have to have a special spanner wrench to remove and reinstall the spanner nut (#12 on the diagram).
- The clutch assembly Part number: AP3094537
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSR8233EZ1 | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 4 time(s).
dryerman101
#3 Posted : Sunday, May 30, 2010 6:47:46 AM(UTC)
dryerman101
Thank you , you were right , unfortunately part of the transmission housing was so worn down that it was not worth putting that much money into a 9 yr. old washer. Thanks again, whenever I have an appliance problem this will be the place I will turn to first.
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
