trey72k
#1 Posted : Sunday, May 16, 2010 10:59:10 AM(UTC)
trey72k
Repair diagnosed side by side with frost build up and no cooling on the Fridge side. Hi said the evaporator motor ("AP3845420") would get the fridge working again.
I order and installed the part. In the box there were two white sleeves? and two small blue cylinder shapped parts, but with no instructions, I don't know where they should be installed.
I was able to replace the motor, but i'm at a loss since the fan is still not own.
Do the blue cylinders and white sleeves need to be installed?
Any help would be appreciated; current living out of a huge cooler.
#2 Posted : Monday, May 17, 2010 5:19:13 AM(UTC)
Replacement parts for FRIGIDAIRE FRS6L9EESS1 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241636600.pdf
And a manual
http://frigidaireservicetips.com/pdfs/496_4.pdf
[COLOR="Blue"]
I order and installed the part. In the box there were two white sleeves? and two small blue cylinder shapped parts, but with no instructions, I don't know where they should be installed.[/COLOR]
I cannot say for sure but the parts you describe sound like a couple in-line wiring connectors and heat shrink tubing. They are only required if upou have to cut the wires and splice in new connections to install the fan motor.
[COLOR="Blue"]I was able to replace the motor, but i'm at a loss since the fan is still not own.[/COLOR]
Check to see if the fan motor is getting pewer (120 volts AC).
If yes, then the fan you received is defective.
If no, then you either have a bad connection somewhere or your control board is shot.
