dean fedewa
#1 Posted : Thursday, May 13, 2010 5:23:08 PM(UTC)
dean fedewa
Everything seems to work fine,It just started to humm after 1sec of hittin the start button.It will not heat now,but I only tried 30sec's a couple of times.Didn't want to mess anything else up...I can fix, just need help troubleshooting.THANKS MUCH.
tvtech
#2 Posted : Friday, May 14, 2010 10:55:55 AM(UTC)
tvtech
only 4 parts involved..
1. big transformer (since its humming probalby ok)
2. big diode.. (check with meter)
3 big cap. (check with meter)
4. magnetron.. (normally the only checks i know of it to verify that with a clamp on amp meter that there is around 8-12 amp going to the magnetron. also unplug and verify that the 2 terminals of the magnetron are not shorted to ground the case)
