bobfixit
#1 Posted: : Saturday, May 10, 2008 9:01:33 AM(UTC)
bobfixit
My wife ran the auto self clean and when it finished it beeped once and the display panel went blank and the oven door remained locked. I have powe to range as the top burner ignite and light. How do I unlock the door and what could be my problem with the display panel? I pressed the puttons nothing happens.
bobfixit
#2 Posted : Saturday, May 10, 2008 12:07:02 PM(UTC)
bobfixit
is there now one out that can help, before I start digging in and taking things apart?
#3 Posted : Saturday, May 10, 2008 5:46:12 PM(UTC)
Bob,
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
UserPostedImage
The oven TOD
UserPostedImage
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
bobfixit
#4 Posted : Tuesday, May 13, 2008 4:00:25 PM(UTC)
bobfixit
Thanks Gene, The TOD was the problem. This site is greate help. And Gene you can't leave.:)
Fixit?
#5 Posted : Sunday, April 4, 2010 1:26:27 PM(UTC)
Fixit?
Sounds like the thermister. Same thing happened to me and I got the wiring diagram located the thermister and checked it with a continuity meter and it read open (bad). I ordered the new part got it within a couple of days and replaced it. Everything works fine now.
