My ice maker voltage is reading 57 volts? I put tape on the flap that blocks the beam and on the light botton so I can see if it will run when it makes the beam.I tried braking the the beam while testing voltage and it never changed? Is there a fuse somewhere? Due to there being some voltage does that mean there is no fuse? I checked to see if it had a good neutral and it did. So now what do I try. Confused when I have some voltage but not the full 120v. I am an electrician so yes I had the meter set right.lol Just incase you where to ask.
Originally Posted by: casadevall2002 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My ice maker voltage is reading 57 volts? I put tape on the flap that blocks the beam and on the light botton so I can see if it will run when it makes the beam.I tried braking the the beam while testing voltage and it never changed? Is there a fuse somewhere? Due to there being some voltage does that mean there is no fuse? I checked to see if it had a good neutral and it did. So now what do I try. Confused when I have some voltage but not the full 120v. I am an electrician so yes I had the meter set right.lol Just incase you where to ask. replace your emitter and receiver boards
Originally Posted by: casadevall2002 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) where is it located? in the walls on either side of the ice maker
I put the new boards in it but it didnt work. Still reads 56 volts at ice maker. now what?
