Mothers day emergency (ha ha)
I checked all cycles gentle, regular, and the other one. it allows water in and does go through the washing cycle. Timer stops when it come's to the first drain and just remains at that point. I move the timer to spin and it doesn't do anything. Any assistance would be appreciated, after looking at the Sunday paper and seeing $$$$.$$ new side loading washing. ANY ASSISTANCE WOULD BE """"GREATLY""""""APPRECIATED!!!!!!!! I have a ballpien hammer, cresent wrence, pipe wrench, bailing wire and I am standing by...... Thanks You John
You need to check the lid switch. But first you need some tools.
Thank you GLEN..... You saved this old Senior a pocket full of money on a new washer... I am just going to put a big RED RIBBON on this old MACHING and a Happy Mothers Day Card on it... """Lid Switch it was""" Your right with the money I saved, I will be able to get those much needed tools down here on the farm. ha ha THANK AGAIN
Lid switch it was hey? “”must have more tools than lead on you do””
I have the same problem on mothers day how did you check the swich
O1SPORTY
I Just put my fingers under the edge and the switch fell off in my hand. I pulled it a little from the edge and pressed down on it, as it was still hooked up and the washer was in the rinse cycle. It immediately started to drain and spin. Sorry I didn't answer sooner. I ordered the part and saved A TON.
Good luck
John
