hi my range started acting up f1 f3 codes. unpluged and replace pulg worked good for a while. oven would light get to temp then not re-light. ingniter comes back on no gas. i replace oven vavle and circut board. didnt fix oven wont start unless tap vavle. you can blow out top burners like blowing out candles. it is like not enough gas?
If your ignitor is mellow orange it may be bad. It should be as bright as the sun. Your oven sensor's quick plug could be contaminated with corrosion or grease. Clean it real good and retry.I bet the whole problem was a weak ignitor. ![APP-meters-circuit-tester.gif APP-meters-circuit-tester.gif](/resource.ashx?p=234&b=1) SublimeMasterJW attached the following image(s):
