14 Pages«<23456>»
#31 Posted : Monday, May 3, 2010 5:55:19 PM(UTC)
The model number you posted does not come up. Verify and repost it.
mn73
#32 Posted : Thursday, May 6, 2010 4:25:51 AM(UTC)
mn73
I have an Amana bottom freezer ARB2214CW - about 8 years old. Had same problem. Fridge died but freezer is just fine.
Repair tech out yesterday showed me frozen freezer coils and replaced thermostat (said heater was fine). Could see thermostat housing had swelled and ruptured. Bottom coils under the fridge are clean. Still, 15 hours post repair fridge temp is not at all improved.
I have to drop another lump of cash on a repair visit - any ideas for parts I can replace myself? Just seems like cold air is not moving into the fridge and I suspect some kind of fan or motor problem but what are the odds both fan and thermostat would fail simultaneously?
#33 Posted : Thursday, May 6, 2010 8:36:29 PM(UTC)
Originally Posted by: mn73 Go to Quoted Post
...I have to drop another lump of cash on a repair visit...
The problem is not solved, the diagnostic is not done properly - why do you have to pay?
mn73
#34 Posted : Friday, May 7, 2010 3:31:38 AM(UTC)
mn73
ahhh...I mistyped originally - should have been "hate to pay"...but, problem remained - thermostat was replaced but no cool air. That said, after reading through these threads all morning I self-diagnosed and determined I needed to try the evaporator fan motor. Local repair shop had one in stock, grabbed at lunch, drove home in the evening and, thanks to the schematics on this site, pulled the thing apart and switched the motor and fan in a matter of minutes. Presto. Cold air, refrigerator operating perfectly. Saved me either $1800 on a new fridge or another $150 on a repair call, either way you dice it.
Which leads me back to the original service call. They don't want to hear my complaint which is, even if the thermostat needed replacing (and I believe them - I saw the coils encased in ice and the ruptured thermostat) shouldn't the repairman have plugged the thing in prior to reassembly just to ensure the fan was blowing (or stuck his hand in front of the fridge vent to ensure air was moving)? Lesson learned. Next time (hoping there isn't one) I'll come here first.
So - back to the original question, though - would failure of thermostat cause the fan motor to go - or vice versa?
#35 Posted : Friday, May 7, 2010 2:24:14 PM(UTC)
The fan motor has nothing to do with the thermostat. They are absolutely separate.
I'm glad you were able to diagnose and fix it it. Good job!
iandylan2330
#36 Posted : Thursday, June 24, 2010 8:24:19 AM(UTC)
iandylan2330
I have a HOTPOINT fridge, model number HTS22GBMARWW
I have noticed a weird buzzing noise from my fridge the past couple weeks. The freezer works just fine. My wife opened the fridge last night and the fridge was warm. At first I thought she just left the door open but found out the fridge wasn't cooling. My first thought was a filter or vent but then thought that if it was a vent the freezer wouldn't be working. I can hear the compressor behind the fridge running. However, instead of a quiet hum, it's sounds like an aggressive loud hum. Any Ideas. I don't have an ice maker.
#37 Posted : Friday, June 25, 2010 4:38:44 PM(UTC)
What is the exact temperature in the freezer?
Can you pinpoint that noise?
Here are the breakdown diagrams and Replacement parts for General Electric HTS22GBMARWW Refrigerator | AppliancePartsPros.com
elderdjrobjr
#38 Posted : Tuesday, July 13, 2010 6:18:44 PM(UTC)
elderdjrobjr
Have a maytag msd2641keb side by side. coils ok. frig warm freezer cold cleared return area of ice and frost, fan starte bac up, but stopped when freezer door was closed. some frost forming on back bottom wall of freezer.
homebrewdon
#39 Posted : Wednesday, July 21, 2010 5:34:31 PM(UTC)
homebrewdon
I have a GE TBFM17VC refrigerator that I inherited and am having issues with. The freezer will cool down to 2.0 deg F on coldest setting, but the fridge maintains the same temp of 50deg despite cooling setting. Nothing is in the fridge except some beer, and there is no ice on the back panel in the freezer, also the freezer fan is blowing strong. I can not detect any fan movement in the fridge. Whats my next step? Thanks.
Don
#40 Posted : Wednesday, July 21, 2010 6:16:35 PM(UTC)
Sorry for the delay.
Remove the rear panel in the freezer and check how the evaporator is covered with snow. Post the results.
Here are the breakdown diagrams and Evaporator/front rollers/water tank replacement parts for MAYTAG MSD2641KEB Ref - SXS/I&W | AppliancePartsPros.com
Guest (12)
GE GBS22HCPAWW - Refrigerator not cooling, but freezer is working (Refrigerator & Freezer Repair)
by drl213 10/16/2009 6:34:42 AM(UTC)
by cdnhawk02 9/14/2009 2:22:31 AM(UTC)
14 Pages«<23456>»
