jlr06tar
#1 Posted : Saturday, May 10, 2008 3:20:49 PM(UTC)
jlr06tar
my washer leaks from bottom looks like it comes from above the transmission and it makes alot of noise in the spin cycle. any ideas
#2 Posted : Saturday, May 10, 2008 6:37:46 PM(UTC)
Sounds like the central seal is leaking and the bearing is damaged too. In order to fix this problem you have to install the triple lip seal & bearing kit.
It comes with the complete installation instructions. Also you have to oder some special tools: the spring removal tool - part number AP3854720, the seal nut - part number AP3873487, the spanner wrench - part number AP3854730 and the central seal grease - part number AP191107 .
- The part number for the triple lip seal & bearing kit is AP4260929
