fpwiv
#1 Posted : Wednesday, May 5, 2010 6:04:44 AM(UTC)
fpwiv
I removed and reinstalled my Bosch D/W with new cabinets, its about a year and half old. The model number I posted is from memory so I will check and post correct number when I get home. When turned on it clicks, thumps a couple times and makes a belching or burping sound. When I try to start a wash cycle it thumps a couple more times, the active indicator on the control panel lights up and then goes out, the clean indicator lights up and stays on that is it, no washing, no water seems to be entering the machine. The clean indicator light stays on and will only go off when the power is turned off. When it ran previously the clean indicator light would go off when the door is opened.
Any ideas would be helpful, thank you.
#2 Posted : Wednesday, May 5, 2010 9:09:54 AM(UTC)
Looks like there is something wrong with the power line connection to the dishwasher. Make sure there is no reversed polarity and the hot (black) wire from the power cord is connected to the hot (black) wire in the dishwasher, and the neutral (white) is connected to the neutral (white) wire in the dishwasher.
fpwiv
#3 Posted : Wednesday, May 5, 2010 5:41:35 PM(UTC)
fpwiv
Thank you for responding promptly. I checked the the wiring and the Black (hot) wire is connnected to the line terminal, the white neutral wire is connected to the neutral terminal and the ground is connected to the ground terminal with green screw. The wires coming out of the back of the terminal block match those going in. This matches my installation instructions. Also this is the same circuit and breaker that the D/W was previously wired to.
Any other ideas what to try next?
Thank you.
Model #SHE4AM02UC/01
fpwiv
#4 Posted : Sunday, May 9, 2010 7:00:06 AM(UTC)
fpwiv
Hi again,
I was able to find instructions for the Customer Service Program. Following the instructions I turned on the DW while holding down the arrow key and delay key, then held the other arrow key until the left program led was lit, then pressed the other arrow key and the Active and Clean program LED's on the control panel lit up and flashed continuosly. The intructions say this code means no drain flow possible or blockade or coil error. Any thoughts on how to solve this would be great. I mentioned previosly the dishwasher worked fine before we removed it. However when I moved it water did come out which could mean it wasn't draining?
Thank you
#5 Posted : Sunday, May 9, 2010 10:52:29 AM(UTC)
Is the drain hose connected to a garbage disposal?
If it is, did you replace the garbage disposal during this remodeling?
If both answers are Yes, make sure the disposal drain plug was removed.
fpwiv
#6 Posted : Monday, May 10, 2010 3:14:18 PM(UTC)
fpwiv
No, we do not have a garbage disposal installed.
#7 Posted : Tuesday, May 11, 2010 11:08:21 AM(UTC)
Unfortunately at this point I have no clue. Very likely something wrong was done during the dishwasher has been moved in and out. I would recommend to call a pro for more specific diagnosis.
fpwiv
#8 Posted : Tuesday, May 11, 2010 3:51:31 PM(UTC)
fpwiv
Thank you For you help Gene. We will take your advice.
#9 Posted : Tuesday, May 11, 2010 5:45:56 PM(UTC)
Guest (7)
