bhavinjo
#1 Posted : Monday, May 3, 2010 6:01:34 PM(UTC)
bhavinjo
Hi
I have a GE refrigerator the freezer section of which is no longer cooling well as also the refrigerator.
There is a lot of ice on the rear wall of the freezer. I checked the defrost heater for continuity and it seems fine.
I ended up changing the main board, part # 801 here.
Sealed system & mother board replacement parts for General Electric GSS25QFMBBB Refrigerator | AppliancePartsPros.com
However, after working fine for a few days, the problem is back.
Not sure what else do I need to change if at all.
Any help is much appreciated.
Thanks!
#2 Posted : Tuesday, May 4, 2010 3:00:11 AM(UTC)
Here are the parts
Replacement parts for GSS25QFMBB models | AppliancePartsPros.com
Did you check the defrost thermostat Section 5 Item 240.
Also if it looks bulged out I would replace it.
Probably not a bad idea to replace the sensor, Item 241.
bhavinjo
#3 Posted : Tuesday, May 4, 2010 6:46:50 AM(UTC)
bhavinjo
Originally Posted by: denman Go to Quoted Post
Here are the parts
Thanks much for the idea.
Do u think I need to replace the Evaporator Fan motor as well? Part # 610?
Part Details - GE Motor, DC Evaporator Fan ( W/O thermister ), part number: AP3875639
Please let me know your thoughts.
#4 Posted : Wednesday, May 5, 2010 3:19:06 AM(UTC)
If the fan is running OK I would not replace it, just a waste of money.
Sounds more like a defrost problem than a fan problem.
bhavinjo
#5 Posted : Wednesday, May 5, 2010 4:26:45 AM(UTC)
bhavinjo
Perfect. Thanks much...:)
I will order only those 2 parts and get back to you in a couple of days.
Guest (6)
