I cannot enter commands using the keypad. Only "0" and "7" on the numbers work. However, all other buttons work.
I shut the breaker off for 30secs and tried but no change.
I removed the keypad and control board, disconnected the ribbon cable, cleaned the contacts with an eraser and alcohol, reinserted adn retried but again with no luck.
Anything else I should do before buying a replacement keypad (PN AP2026342)?
If I have to replace the keypad, any advice on installation? It looks like the pad is glued to the metal support and I have to "peel" off the old one? Is that right?
Thx
