leej
#1 Posted : 15 years ago
leej
The heat in the upper oven will not sustain a set temperature and keeps flunctuating. I am thinking its some sort of sensor or thermostat?? Thanks
#2 Posted : 15 years ago
Measure the resistance of the oven sensor (#12 in the diagram). It suppose to be about 1100 Ohms at the room temperature. If there is nothing wrong, replace the control board.
- The oven sensor Part number: AP4009009
Jenn air oven misbehaving (Oven Repair (including Ranges and Cooktops))
by arn09 10 years ago
How to remove a Jenn Air Oven Door and possible Hinge replacement (Oven Repair (including Ranges and Cooktops))
by williefan 10 years ago
Jenn Air OVEN LIGHT WILL NOT SHUT OFF (Oven Repair (including Ranges and Cooktops))
by smylist 10 years ago
Jenn Air oven won't heat all the way (Oven Repair (including Ranges and Cooktops))
by dmd1 11 years ago
Jenn Air oven keep warm setting overheats (Oven Repair (including Ranges and Cooktops))
by scottmt 11 years ago
jenn air oven (Oven Repair (including Ranges and Cooktops))
by jcvencill 12 years ago
Jenn Air Oven not heating and light comes on by itself (Oven Repair (including Ranges and Cooktops))
by tdjohnson740 13 years ago
Jenn air oven light won't turn off (Oven Repair (including Ranges and Cooktops))
by janna bestul 13 years ago
Jenn Air oven door does not close all the way (Oven Repair (including Ranges and Cooktops))
by Meyekal 13 years ago
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 14 years ago
Problem with Jenn Air oven (Oven Repair (including Ranges and Cooktops))
by johncher 14 years ago
Jenn Air Oven Display and Controls Broken (Oven Repair (including Ranges and Cooktops))
by nittanykid 14 years ago
Jenn air oven problems (Oven Repair (including Ranges and Cooktops))
by patrickC 15 years ago
1970's Jenn Air Oven - Model Id (Oven Repair (including Ranges and Cooktops))
by dug320 15 years ago
Jenn air oven no display but works (Oven Repair (including Ranges and Cooktops))
by Gary E 15 years ago
