HI Helper
#1 Posted : Tuesday, May 6, 2008 11:26:31 AM(UTC)
HI Helper
I have a Kenmore washing machine. It is a direct drive. In the rinse and spin cycles there is this clicking noise. Everything seems to still work properly. No oil leaking, I can move the agitator freely, doesn't stop abruptly after spin. water drains properly. As the clicking occurs I seem to be able to "feel" it in the gearcase. So I have removed the cabinet, spanner nut, outer tub ring, inner tub.
1. How do I remove the basket drive block? Special tool?
2. If it is the gear box, how do I remove it? are there any seals I MUST replace?
3. Is this for the DIY'er? Or leave to a professional?
pics attached
HI Helper attached the following image(s):
richappy
#2 Posted : Wednesday, May 7, 2008 2:44:29 AM(UTC)
richappy
It looks like your spin basket is rusting out! I would check it, maybe cracked.
If ok, remove the pump and motor and turn the coupler on the tranny clockwise till the spin tube turns. If you feel a rough spot, it's probably your tranny acting up. Also look for tranny oil overflowing, if so, this confirms a bad tranny.
MAV7600AWW makes loud noise during spin cylce (Washer Repair)
by Guest 6/14/2021 6:09:42 PM(UTC)
Whrlpool Duet Sport Noise During Spin Cycle (Washer Repair)
by ekbaldwin 2/13/2021 9:37:54 AM(UTC)
Maytag washer clicking noise during spin (Washer Repair)
by jeff.shields1 11/12/2018 9:21:41 AM(UTC)
Noise during spin cycle (Washer Repair)
by ArthurJ 8/10/2018 3:36:59 AM(UTC)
GE washer making loud noise during spin cycle (Washer Repair)
by vinnyb 1/23/2016 10:58:06 AM(UTC)
Admiral capacity max washer makes noise during spin and agitate modes (Washer Repair)
by ENielsA 1/1/2016 6:59:11 PM(UTC)
Awful noise during spin cycle (Washer Repair)
by LordUgh 10/6/2015 10:47:33 AM(UTC)
Rumbling noise during spin cycle (Washer Repair)
by hsrace1128 4/16/2015 7:26:36 AM(UTC)
Load noise during spin (Washer Repair)
by yamaboy 5/14/2014 5:56:29 PM(UTC)
Electrolux- knocking noise during spin cycle (Washer Repair)
Belarus Chelean 12/31/2013 11:07:37 PM(UTC)
by Deebo__ 11/26/2013 12:09:59 PM(UTC)
clicking noise during spincycle (Washer Repair)
by hnsberk 5/15/2013 6:05:57 AM(UTC)
Knocking noise during spin won't drain (Washer Repair)
by brun0 2/13/2013 7:40:34 PM(UTC)
by ronpadz 2/11/2013 7:26:05 PM(UTC)
GE front load washer making loud noise during spin cycle (Washer Repair)
by wendyyx33 11/29/2012 8:41:29 AM(UTC)
