This unit shuts down on me after 2 minutes. After about five minutes it comes back on but you then have to reset the time and again it shuts down in just over 2 minutes. Any body know what might be wrong? Thanks Mark
Hi Mark,
Most likely the problem is a faulty cooling fan inside the microwave.
If the microwave is less then a year old, it should be under the manufacturer warranty.
Thanks Gene, I contacted Magic Chief but they didn't have a repair service near me so I was told to cut off the cord and return it for a refund. Which I will do, but... being frugal and not wanting to throw out a 2 month old Microwave I would like to try to fix it. I will take the unit apart this weekend and see what's up with the fan? While I have it apart is there anything else I should be looking for?
I will let you know how I make out and thanks for your advice! Mark
Hi Mark,
Post your findings after you will check it.
Thanks Gene!! I FINALLY found the time to take the unit apart and found the fan housing had cracked and was blocking the fan blade, just as you had advised. I repaired it and it works perfect. Thanks again, Mark
I'm glad you were able to fix it.
