checkerkitty
#1 Posted : 15 years ago
checkerkitty
A couple of weeks ago I was washing a king sized waterproof mattress protector. During the final spin cycle, the washer started making a noise that sounded like a loud vibration or grunting sound that got louder and longer and ended in a banging sound. I stopped the washer and found the protector holding at least a gallon of water. I dumped the water and spun it out without a problem. I unplugged the washer for good measure. I have had two weeks of perfect operation.
Today I was running a load of bath towels after multiple loads of lighter clothes and sheets. I heard the noise again during the final spin. The washer was spinning just fine. The sound is coming from the back, left side of the washer as you face it. The sound is intermittent at first. It will vibrate for a few seconds, stop for a few seconds, then vibrate again. The sound and vibration gets longer and longer and louder. Then the sound just kept going so I stopped the washer.
A local repair man said it is probably the motor or something stuck between the two drums, but most likely the motor. My husband took the access door off the back and turned the drum. The motor makes a slight rasping sound like the bearings are dry or rubbing. My husband can replace the motor, but we wanted other opinions to make sure this is the problem. Is the motor just starting to go? Is it something else? The machine is only 2 1/2 years old and we never expected problems, especially this soon. I would rather repair than replace, if feasible. Any help is appreciated.
Christy
sidfink43
#2 Posted : 15 years ago
sidfink43
Your type of problem is hard to diagnose on a Forum like this because the main way we do so is to take off the back, run the machine and try to determine where the noise is coming from.
I think it is likely the problem is coming from some other source then the motor. Run the machine with the back off and determine if you can locate the source of the problem, paying particular attention to the support structure and the rear bearing. If they are ok, and the noise is coming from the motor then go ahead and replace it. These models are known for problems in the support area, although yours is a little young to be having them.
Also, I know you are now aware of this, but I will repeat it for other viewers. One reason they invented laundramats is for things like king sized bed protectors. Those places have large heavy duty machines which can wash an item like that.
Here is a service manual which should help if you have to tear into the machine.
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
