dalan
#1 Posted : Friday, May 2, 2008 5:36:04 PM(UTC)
dalan
I replaced the direct drive coupling on the washer but the spin cycle will not work. The agitate cycle is working properly and the pump is working properly.
bambiblaster
#2 Posted : Saturday, May 3, 2008 3:20:10 AM(UTC)
bambiblaster
Was the a slight oil messon the trany when you were under there or even on the inside of cabinet about 6 inches up was the a line of oil/greese... if so trans is leaking oil and has coated the clutch pads and clutch will need replaced
dalan
#3 Posted : Saturday, May 3, 2008 10:30:12 AM(UTC)
dalan
There was no signs of oil. I just ran a cycle and the spin doesnt work throughout the washing cycle. It fills, agitates, drains then no spin, rinses, drains, no final spin.
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
GE washer will not spin (Washer Repair)
Belarus MS104 5/10/2016 4:34:48 PM(UTC)
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 8/26/2015 7:56:10 PM(UTC)
by howard6168 7/5/2015 5:47:41 AM(UTC)
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 6/18/2015 12:01:29 PM(UTC)
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 4/30/2015 11:33:25 AM(UTC)
washer will not spin out (Washer Repair)
by kdwarren16yrs 12/27/2014 6:42:50 AM(UTC)
ge profile washer will not spin (Washer Repair)
by ron dog 11/29/2014 5:27:31 PM(UTC)
Washer will not spin/drain (work) (Washer Repair)
by dupdc 8/20/2014 2:50:08 AM(UTC)
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 5/7/2014 6:40:52 PM(UTC)
