mdevore
#1 Posted : Thursday, May 1, 2008 8:10:40 PM(UTC)
mdevore
need to replace the direct drive assembly but don't know how to take motor off / or outside case . when lay on side oil comes out any directions thanks morris mdevore@inbox.com
richappy
#2 Posted : Friday, May 2, 2008 1:03:28 AM(UTC)
richappy
If the washer was slinging out oil before, you have a bad tranny. Remove panel screws, tilt panel back, remove the spring clips, remove lit switch connector, and remove outer shell. Look at tranny for oil leaking. If so, you have a bad tranny.
IWNTMORHP!!
#3 Posted : Sunday, May 11, 2008 6:26:52 AM(UTC)
IWNTMORHP!!
it wasn't on mine...i was an idiot and left it on it's side and it drained out...can you refill the transmission? if so how?
richappy
#4 Posted : Sunday, May 11, 2008 9:13:23 AM(UTC)
richappy
Clamp the tranny in a bench vise, make it level, then take the cover off and re-fill with 90 weight gear oil.
IWNTMORHP!!
#5 Posted : Sunday, May 11, 2008 9:41:26 AM(UTC)
IWNTMORHP!!
thank you very much...i will give it a shot!
#6 Posted : Sunday, May 11, 2008 3:37:48 PM(UTC)
The part number for the gear case oil is AP3072960
Guest (5)
Kenmore washer/dryer stackable combo stops (Washer Repair)
by philio22 5/1/2022 5:30:10 PM(UTC)
Kenmore washer/dryer (Washer Repair)
by Candide 3/6/2021 8:42:51 AM(UTC)
Kenmore Washer/Dryer Combo Model 110.88752794 (Washer Repair)
by SMBrian 4/22/2019 6:28:33 AM(UTC)
Dryer in kenmore washer/dryer stackable wont stop buzzing, and runs with door open (Dryer Repair)
by craighouseholder 5/1/2015 5:52:53 AM(UTC)
Kenmore washer/dryer combo installation instructions (Washer Repair)
by hollyinrio 6/14/2012 4:29:00 PM(UTC)
Kenmore Washer/dryer combo (Washer Repair)
by dbscotties 11/29/2011 7:46:48 PM(UTC)
kenmore washer/dryer combo (Washer Repair)
by vbc999 11/14/2011 12:09:02 PM(UTC)
Kenmore Washer/Dryer Combo (Dryer Repair)
by Boxxcarr 11/11/2009 2:16:26 PM(UTC)
Kenmore washer/dryer combo (Dryer Repair)
by kwp 10/12/2009 9:54:03 AM(UTC)
Kenmore Washer/Dryer combo won't drain or spin (Washer Repair)
by uttdawg 5/26/2009 11:07:57 AM(UTC)
