Danny Carter
#1 Posted : Thursday, May 1, 2008 8:04:46 AM(UTC)
Danny Carter
Can you please advise me how to install the new door to my GE microwave?
#2 Posted : Thursday, May 1, 2008 5:06:58 PM(UTC)
Danny,
You have to remove the microwave from the oven cabinet.
Danny Carter
#3 Posted : Thursday, May 1, 2008 7:30:49 PM(UTC)
Danny Carter
Dear Gene,
Thanks for your reply,this microwave is mounted above the oven and I will pull it out if necessary as you stated. It appears that the current door is attached and pivots by 2 metal hinges (1) at the top left corner and (1) at the bottom left corner. My question is how do I take the old door off and then replace it with the new one. Also are you sure I need to pull it out because it appears there are pins hinge that hold the door on. Please reply and thanks again for your info. Danny
stallm
#4 Posted : Thursday, May 8, 2008 1:15:09 PM(UTC)
stallm
I also have the similar need..
I have a GE Profile Microwave (JVM1460WA), which is about 10 years old, has lots of cracks around the door, and latch/spring action is broken. Instead of replacing the individual parts, I'm thinking of replacing the whole 'door assembly' (part # AP2033297).
Wondering if anyone has comments on how easy / difficult to install, any links to instructions is greatly appreciated.
Thanks,
Sam
#5 Posted : Friday, May 9, 2008 12:41:43 PM(UTC)
Hi Danny,
There are two door hinges (upper & bottom) which are mounted with two screws each. You can reach these hinges only after the microwave is out of the cabinet.
dsdand
#6 Posted : Thursday, August 7, 2008 9:02:17 AM(UTC)
dsdand
I have a Whirlpool mh7140XFQ0. All it really needs is the outer door casing replaced. I see they sell it but without instructions???
installing new door handle (Microwave Repair)
by czina27 9/8/2010 10:25:24 AM(UTC)
