My through-the-wall room air conditioner (2 years old) turns on and blows air, but the compressor doesn't kick in for a few minutes and then, when it finally does, it will only run for a few minutes before shutting off and going back to just blowing ambient air. Any help appreciated.
You have been a member since:: 4/19/2010(UTC) Posts: 2
Could be a number of things. As far as thing that could be causing this that you could repair yourself. For starters I would check and make sure the outdoor coil is clean and the outdoor section is moving air as well. What size unit do you have?
Possible bad capacitor. :)
Compressor cutting out on the overload-could be pulling to many amps need a/c technician
