Originally Posted by: TJ17 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Gene, Been in circles with our GE Profile freezer bottom the last month or so... About 6 weeks ago our fridge got warm, freezer was fine. Repair guy switched out the main board / 24 hr defrost and it worked for fine for a month. Then we had the same problem. This time he says the main board is fine but, can't find the problem. Cool air comes through to the fridge only when the freezer is open. We've cleared all food so nothing is blocking... Any ideas?
THANK YOU!:confused: Possible the air return from the fresh food compartment into the freezer is blocked. Gene.
Gene, Thank you for your reply. The model # is GSH22JFTA CC. Like I said I replaced the main control board as well as the upper thermistor. I jumped the heater wire on the board and the heater glows red. I suppose this means the thermostat as well as the heater is functioning correctly. The only thing I didn't replace was the lower thermistor. Could this be the problem? The upper thermistor did have some black on the tip. Thank you for your quick reply.
Sounds really strange. Replace the second thermistor and, if it would not solve the problem, then probably one of new parts is defective.
Hello Gene,
Perhaps you can get me sorted. I have a non-working GE GSL22JFPH BS, neither the fridge nor the freezer seem to be cooling. I ordered an new motherboard, although the fridge seems to be running, although the compressor does seem quiet (perhaps it's just that way on this model?) I installed the new mobo part #AP4436216, but the unit is still not cooling down. Any idea what other problems I should turn my attention to? Any assistance would be appreciated greatly. TIA
Do0d
I can feel the compressor running & it feels cold to the touch. Where should I be looking fopr the fans? I checked inside the back wall of fridge & freezer and felt some slight air movement, or should I be looking at the fan at the bottom rear of the unit, below the motherboard access area?
If the compressor is running but it is cold on touch, then there is a problem with the sealed (cooling) system. It has to be diagnosed by a pro. You have to call GE to find out if it's still under the warranty.
Thanks Gene,
I havve a guy coming out tomorrow to check it out further. I appreciate all the help. This forum is fantastic, seeing how many people got their appliances working again is very inspiring to the do-it-yourselfer!
Thanks again!
