RJ Trucks
#1 Posted : Tuesday, July 28, 2009 10:52:36 AM(UTC)
RJ Trucks
Whirlpool electric dryer not heating. Assumed it was heating element and replaced. Dryer is still not heating. Any other ideas on what could be wrong. This has been a very good dryer and I don't want to replace.:confused:
Thanks rj trucks
sidfink43
#2 Posted : Thursday, July 30, 2009 4:54:36 PM(UTC)
sidfink43
When you replaced the heating element you should have seen thermal fusesand thermostats. Check them for continuity, particularly the thermal fuse. Make sure the dryer is thoroughly cleaned of lint, particularly in the exhaust vent and blower
Before doing that, check to see that you are getting 120 volts to each side of the connection block. Then unplug the machine to do the other checks.
Good luck.
crystalskarsvog
#3 Posted : Monday, April 12, 2010 8:35:34 PM(UTC)
crystalskarsvog
my sister in law gave me and my husband a washer and dryer. but the dryer went out and she had some one come look at and they said it was the thurmistat and they replaced those but it still didnt heat up so she thought it was the heating element and we got the part and replaced it and its still not heating up its frustrating cuz we really need it with 6 ppl in the same house and a baby on the way.. HELP!!!!!
sidfink43
#4 Posted : Tuesday, April 13, 2010 3:27:45 AM(UTC)
sidfink43
If you will post the brand and model number of the machine someone should be able to help you. Please start a new thread and describe in as much detail as you think appropriate how the machine is operating. I am assuming that it runs but no heat comes out, and that this happens in all cycles.
#5 Posted : Tuesday, April 13, 2010 3:50:11 AM(UTC)
crystalskarsvog
#6 Posted : Tuesday, April 13, 2010 7:45:45 AM(UTC)
crystalskarsvog
all i know right now with the dry is that it spins but its not drying and the thermistats have been replace along with the heating element. its a whirlpool dryer and old one at that the model number is LE5720XSW1. it just suks that i wont dry its a good dry when it worked i just cant find anything online and me and my husband have no money to get it looked at or buy something for it.
#7 Posted : Wednesday, April 14, 2010 1:23:12 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203393987.pdf
You could always borrow a meter.
As sidfink43 said you have to check the power first, could be there is nothing wrong with the dryer. The motor and timer run off half the line (120 volts) but the heater requires the full 240 volts.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Be sure to disconnect one side of and device you are measuring this prevents reading an alternate/parallel circuit path. Also use your most sensitive ohms scale.
There is a good Sticky at the beginning of this forum on meter usage.
juanrodman
#8 Posted : Thursday, September 9, 2010 7:53:32 AM(UTC)
juanrodman
I have a Whirlpool model LEC8858DQ0. I went through the complete sequence with a meter and find no problem with power at wall or terminal strip, and continuity on thermostats, thermal fuse, or heating coil. The lint path is clean and I am stumped! Thanks for the tremendous help!
#9 Posted : Thursday, September 9, 2010 7:58:25 AM(UTC)
juanrodman
Please start your own thread using Post New Topic in the dryer section.
It will just get confusing trying to troubleshoot 2 different models even if the symptoms are the same
Guest (5)
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by bselff 12/20/2011 12:58:18 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
electric dryer not heating (Dryer Repair)
by notimetowait 10/1/2010 6:26:06 PM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
by 18wheeler 1/30/2010 9:16:47 AM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not heating (Dryer Repair)
by Danske 11/23/2009 4:19:41 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
by Global Kiss 7/16/2009 10:33:02 AM(UTC)
