beanocook
#1 Posted : Monday, April 12, 2010 5:27:45 AM(UTC)
beanocook
Hi -
First my question... Can a broken thermostat cause the motor to stop working, but allow the heating element to still heat up?
A few weeks back our dryer stopped working. That is, the motor stopped turning the drum, but the heating element kicks in. When I turn on the power, I don't hear a single noise from the motor. From different "do-it-yourself" guides, walking through the checklists I find that the thermostat fails the continuity check. Although this may in fact be the problem, it doesn't make sense to me why it would cause the motor to stop working but allow the heating element to keep working? Logically I would expect the opposite behavior.
-thanks in advance
Glenn
magician59
#2 Posted : Monday, April 12, 2010 7:05:20 AM(UTC)
magician59
Does the motor hum like it's trying to turn? Check for lint build-up in the motor area. Sometimes the motor switch can become blocked open by lint. [COLOR="Red"]Don't do any work around the motor until you have unplugged the dryer[/COLOR].
beanocook
#3 Posted : Tuesday, April 13, 2010 6:46:06 AM(UTC)
beanocook
Magician59 -
Thanks for the quick response, could you point me to any documentation on these motors? Is it simply a matter of cleaning up the dirt and the lint off of the motor? This is the first problem I have attempted to trouble shoot and I am not sure where to find the switch you mention.
-thanks in advance
Glenn
magician59
#4 Posted : Tuesday, April 13, 2010 7:15:35 AM(UTC)
magician59
The motor has a mechanical switch built into it. It used to be a replacable switch, but now it is an integral part of the motor. It has two functions. At rest, it closes contacts between the motor start winding and neutral. When the motor ramps up to speed, centrifugal force opens this contact, dropping the start winding out of the circuit. At the same time, this centrifugal force closes contacts on the same switch between the heat circuit and neutral, allowing the heat to come on. This is designed so that no heat will come on until the air is circulating in the dryer.
Sometimes lint build-up causes this switch to remain in the "run" position, causing the motor not to start, but allowing heat to be energized. This will eventually burn out the motor run winding as it attempts to start without the aid of the start winding. It can also present a fire hazzard, with the heat being activated without ventilation.
This may not be your problem, but it's a good place to start troubleshooting. Just unplug the dryer, open it up and vacuum out the motor unit as thoroughly as you can, and see if the dryer will start.
